Hello:
We have 2 tic 249 drivers with the same motor setups. When I run home command one of the drivers works correctly and releases the switch after hitting the limit switch. But the other hits the limit switch but does not release it. Any idea why?
Thanks,
Farhad
Hello, Farhad.
Could you post pictures of your setup that show all of your connections and clearly indicate which one is which? If the two setups are identical, can you try swapping the Tics and seeing if the problem follows the Tic or the setup?
Also, could you post the settings files for each Tic and clearly indicate which one is for which Tic? You can save a copy of the settings file from the “File” drop-down menu of the Tic Control Center while the controller is connected.
