I am looking for a high torque (>200 oz/in) stepper motor for use in creating a DIY proportional valve. I can only find MUCH smaller steppers (44 oz/in). I would prefer not to gear them because that will slow things down. I would like to have a full revolution be under 2 seconds. Does anyone have any ideas on a solution that might work?
I guess I don’t understand the problem. I’m just learning about these, but it seems that MANY steppers are rated over 200 oz/in without being geared or too expensive. They are BIG, heavy, and eat watts but they exist.
Here is just one that I happened to find easily:
interinar.com/4023-833.html
There are many such stepper motors, as noted above.
Look into the DIY CNC groups. That’s where you’ll find almost all of the info. Most of Pololu’s stuff is a very quality source for 3D printer projects and smaller CNC machines, but they don’t work as heavily in the higher power steppers (from my brief search the other day.)
But come back here for everything else you need- there’s a lot of great stuff.
Consider too, however, whether or not a continuous rotation servo motor or a geared 37D with an encoder will work for you application. Depends on how quickly and how accurately you need to rotate your device.
