Is the noise the only issue with the setup right now, or is there anything else that is also not working? It is hard to speculate about what might be causing noise like that without actually hearing it or knowing more about your setup. A video that shows the problem as well as some pictures showing all of the connections in your system would be helpful. The forum does not allow users to post very large videos, but it does work well with videos linked from other sites (like YouTube or Vimeo).
Can you also let us know what specific stepper motor and power supply you are using as well as what VREF is set to on your board?
There could be several possible causes for noise, so you might consider changing some of these variable to see if they change the results:
Remove any load attached to your motor’s output shaft and remove the gearbox
