I read through a couple of the other threads but it seems that nobody really answered this question yet. So I apologize if this was already solved.
This is for Product 752.
Here is my issue:
I have a 12V LED Strip that eats 400mAh. The LED Strip I want to control ON/OFF from the Pololu RC Switch … I understand that I can’t do this directly but with a Transistor. My knowledge is pretty ancient on Transistors, so I might need a refreshment and would like to ask if somebody can walk me through.
The whole thing would be powered using a 3S 11.1V LiPo… The LiPo also will power a BEC that provides 5V to the Switch.
I have this Transistor available: eng.yale.edu/ee-labs/morse/c … 2222-d.pdf
So this would be my solution (which could be completely wrong):
Pololu Switch = PS
- Connect LiPo to BEC -> BEC to RC-Receiver -> RC-Receiver to PC
- Bridge PC VCC, so it’s powered from the RC Receiver
- Connect LiPo directly to the LED Strip
- LED Strip is connected to Transistor Collector and Emitter to Ground (NPN Transistor)
- Connect PC OUT to Transistor Base and GND to Emitter/Ground
Thanks,
Andy
