Help, I am attempting to connect a Omron E3Z-D61 & 62 sensor to my svp-128. Is there any particular way to connect and program? Thanks
It looks like those sensors use an open-collector output. If that is the case, you could put a pull-up resistor on the output of the sensor and measure its state with your Orangutan SVP. If you do not want to add an external pull-up resistor, you could enable the internal pull-up resistor on the input you are using to read the sensor.
- Jeremy
What amount of resistances must I use for the circuit?
You might try using a 10 kΩ pull-up resistor.
- Jeremy
