Good Afternoon all,
Im a complete novice when it comes to scripting. I have a working script below (press the button to open the servo, press again to close) and want to add an extra servo to do the same at the same time, problem is…I have no idea how to do it!
Im using the Mini maestro 12 channel, could anyone provide me with the code to attach extra servos to the spare ports? Im sorry it will have to be at the most basic level.
This is the current code;
[code]goto main_loop # Run the main loop when the script starts (see below).
This subroutine returns 1 if the button is pressed, 0 otherwise.
To convert the input value (0-1023) to a digital value (0 or 1) representing
the state of the button, we make a comparison to an arbitrary threshold (500).
This subroutine puts a logical value of 1 or a 0 on the stack, depending
on whether the button is pressed or not.
sub button
0 get_position 500 less_than
return
This subroutine uses the BUTTON subroutine above to wait for a button press,
including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
An example of how to use wait_for_button_press is shown below:
Uses WAIT_FOR_BUTTON_PRESS to allow a user to step through
a sequence of positions on servo 1.
main_loop:
begin
1229 frame
5000 frame
repeat
sub frame
1 servo
return[/code]
Thank you in advance, Chris
