**Hi guys **
**I need help. I am working with Arduino uno. **
**and I bought 2 LPS25H sensors (https://www.pololu.com/product/2724). **
The first sensor was so easy to read out, so I was so happy.
**But when I wanted to read both out at the same time, I had a Problem because they have the same address. So I bought the multiplexer (TCA9548A) it seemed straight forward. **
There is even a very nice guide in whih they also used 2 sensors with the same address. That seemed to solve my Problem (https://learn.adafruit.com/adafruit-tca9548a-1-to-8-i2c-multiplexer-breakout/wiring-and-test) but of Course…they are using no pressure sensors.
So now I am stuck. And really need someones help. Because I have no clue about the LPS.h library which the LPS25H is using. I will post the two codes I have.
So the Code they used to read out the acceleration sensors is this:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
#define TCAADDR 0x70
/* Assign a unique ID to this sensor at the same time */
Adafruit_HMC5883_Unified mag1 = Adafruit_HMC5883_Unified(1);
Adafruit_HMC5883_Unified mag2 = Adafruit_HMC5883_Unified(2);
void displaySensorDetails(Adafruit_HMC5883_Unified *mag)
sensor_t sensor;
mag->getSensor(&sensor);
Serial.println("------------------------------------");
Serial.print ("Sensor: "); Serial.println(sensor.name);
Serial.print ("Driver Ver: "); Serial.println(sensor.version);
Serial.print ("Unique ID: "); Serial.println(sensor.sensor_id);
Serial.print ("Max Value: "); Serial.print(sensor.max_value); Serial.println(" uT");
Serial.print ("Min Value: "); Serial.print(sensor.min_value); Serial.println(" uT");
Serial.print ("Resolution: "); Serial.print(sensor.resolution); Serial.println(" uT");
Serial.println("");
delay(500);
void tcaselect(uint8_t i) {
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
void setup(void)
Serial.begin(9600);
Serial.println("HMC5883 Magnetometer Test"); Serial.println("");
/* Initialise the 1st sensor */
tcaselect(2);
if(!mag1.begin())
/* There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while(1);
/* Initialise the 2nd sensor */
tcaselect(6);
if(!mag2.begin())
while(1);
/* Display some basic information on this sensor */
tcaselect(2);
displaySensorDetails(&mag1);
tcaselect(6);
displaySensorDetails(&mag2);
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
tcaselect(2);
mag1.getEvent(&event);
/* Display the results (magnetic vector values are in micro-Tesla (uT)) */
Serial.print("Sensor #1 - ");
Serial.print("X: "); Serial.print(event.magnetic.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.magnetic.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.magnetic.z); Serial.print(" ");Serial.println("uT");
tcaselect(6);
mag2.getEvent(&event);
Serial.print("Sensor #2 - ");
delay(500);
**And from the Adafruit Forum one person replied and told me I need to include the tcaselect function in my code. **
–>You can call that function in you loop() to select the channel for the sensor you want to read.
if (i > 7) return;
Wire.write(1 << i);
The Code which is used for the LPS25H sensors is the following:
#include <Wire.h>
#include <LPS.h>
LPS ps;
void setup()
Serial.begin(9600);
Wire.begin();
if (!ps.init())
Serial.println("Failed to autodetect pressure sensor!");
while (1);
ps.enableDefault();
SerialMetric
void loop()
float pressure = ps.readPressureMillibars();
float altitude = ps.pressureToAltitudeMeters(pressure);
float temperature = ps.readTemperatureC();
Serial.print("p: ");
Serial.print(pressure);
Serial.print(" mbar\ta: ");
Serial.print(altitude);
Serial.print(" m\tt: ");
Serial.print(temperature);
Serial.println(" deg C");
delay(100);
I really dont know how to Combine them. Can please someone help. I would be so happy!!!
Thanks so much for all your help.
