I was experimenting with the MiniMaestro Pololu Library for Arduino.
Everything worked very perfect and the servos are doing what they are supposed to do.
Now, I am working to create some structure for my code in which it will be more simple to read, for instance, I intend to create some classes to activate different parts of my robot and of course I would like to include the amazing Pololu library MiniMaestro for this purpose.
Before pasting my code I wanted to specify my question. Usually what I learned from libraries working in different parts of code, is required to add #ifndef or #ifdef depending what we want to compile first since this causes conflicts when the same class or library when is declared twice. In this case the line which contains #include <PololuMaestro.h> is declared twice in my *.ino and *.h . I do not get any error when I compile which is good but I do not fully understand if this is due to the nature more “global” of this library, compare to my class initial_position.h
I am very new in programming and any orientation to a proper lecture to understand in deep the basics would be super helpful, my apologies if I am not clear and I would be glad to provide more details.
main.ino
> #ifdef SERIAL_PORT_HARDWARE_OPEN
> #define maestroSerial SERIAL_PORT_HARDWARE_OPEN
> #else
> #include <SoftwareSerial.h>
> SoftwareSerial maestroSerial(0, 1);
> #endif
> MiniMaestro maestro(maestroSerial);
> #include "initial_position.h"
> int CHANNELRA = 0;
> int CHANNELLA = 2;
> int CHANNELRP = 3;
> int CHANNELLP = 1;
> int CSPEED = 0;
> int TARGETMAX = 8000;
> int TARGETMIN = 4000;
> int TARGETMID = 6000;
> initial_position InitialPosition(CHANNELRA, CHANNELLA, CHANNELRP, CHANNELLP, CSPEED, TARGETMAX, TARGETMIN, TARGETMID);
> void setup() {
> // put your setup code here, to run once:
> maestroSerial.begin(9600);
> InitialPosition.ZeroArms();
> void loop() {
initial_position.h
> class initial_position {
> int ChannelRightArm;
> int ChannelLeftArm;
> int ChannelRightPalm;
> int ChannelLeftPalm;
> int SpeedC;
> int TargetMax;
> int TargetMin;
> int TargetMid;
> public:
> initial_position(int _ChannelRightArm, int _ChannelLeftArm, int _ChannelRightPalm, int _ChannelLeftPalm, int _SpeedC, int _TargetMax, int _TargetMin, int _TargetMid )
> ChannelRightArm = _ChannelRightArm;
> ChannelLeftArm = _ChannelLeftArm ;
> ChannelRightPalm = _ChannelRightPalm;
> ChannelLeftPalm = _ChannelLeftPalm;
> SpeedC = _SpeedC ;
> TargetMax = _TargetMax ;
> TargetMin = _TargetMin ;
> TargetMid = _TargetMid ;
> void ZeroArms() {
> //robot returns to original position
> //left palm in channel 1
> maestro.setTarget(ChannelLeftPalm, TargetMid);
> //right palm in channel 3
> maestro.setTarget(ChannelRightArm, TargetMid);
> //right arm in channel 0,
> maestro.setTarget(ChannelRightArm, TargetMin);
> //left arm in channel 2
> maestro.setTarget(ChannelLeftArm, TargetMax);
