I got trouble using this sensor, can i get an example C program ? i’m using my own microcontroller board, and i still confused with this “Measure the time for the capacitor to discharge by waiting for the I/O line to go low”…thx
The program you write will depend completely on the microcontroller you are using, but it will be something like:
int readSensor()
sensor_pin = OUTPUT; // make sensor pin an output
sensor_pin = HIGH; // drive sensor pin high
delay_us(10); // wait for 10 us
sensor_pin = INPUT; // make sensor pin a HIGH-IMPEDANCE input
startTimer(); // start timing (e.g. clear the timer counter)
while (sensor_pin == HIGH && timerCounter < TIMEOUT) // loop while sensor pin is high
return timerCounter;
The above pseudocode reads a single QTR-RC sensor. You will probably want to do something more complicated to read all 8 sensors simultaneously. Take a look at our QTR sensor source code in the Pololu AVR library for C code that works on an AVR. You will need to modify it for your particular microcontroller, but it should give you a good starting point.
- Ben
