Thanks for the quick response, David.
You asked:
Did you port all of the example Arduino code to use the Pololu AVR Library? – Yes. I have included the complete program below. My confusion is mainly with what to substitute for the pinMode() and digitalWrite() functions.
[code]#define F_CPU 20000000UL // Baby Orangutan frequency (20MHz)
#include <math.h>
#include <avr/io.h>
#include <util/delay.h> // uses F_CPU to achieve us and ms delays
#include <pololu/orangutan.h>
#include <stdlib.h>
void delayms( uint16_t millis ) {
while ( millis ) {
_delay_ms( 1 );
millis--;
/ BABY O PINS <==> HM55B PINS
// PB0:IO_B0 <==> #4:CLK
// PB1:IO_B1 <==> #5/Enable
// PB2:IO_B2 <==> #1:Dout,#2:Din
int X_Data = 0;
int Y_Data = 0;
int angle;
unsigned char return_value_of_pin;
//// FUNCTIONS
void ShiftOut(int Value, int BitsCount) {
for(int i = BitsCount; i >= 0; i–)
set_digital_output(IO_B0, LOW);
if ((Value & 1 << i) == ( 1 << i))
set_digital_output(IO_B2, HIGH);
//Serial.print(“1”);
else
set_digital_output(IO_B2, LOW);
//Serial.print(“0”);
set_digital_output(IO_B0, HIGH);
delayMicroseconds(1);
int ShiftIn(int BitsCount) {
int ShiftIn_result;
ShiftIn_result = 0;
set_digital_input(IO_B2, PULL_UP_ENABLED);
for(int i = BitsCount; i >= 0; i–) {
if (is_digital_input_high(IO_B2)) {
ShiftIn_result = (ShiftIn_result << 1) + 1;
//Serial.print(“x”);
else {
ShiftIn_result = (ShiftIn_result << 1) + 0;
//Serial.print("_");
if ((ShiftIn_result & 1 << 11) == 1 << 11) {
ShiftIn_result = (0B11111000 << 8) | ShiftIn_result;
return ShiftIn_result;
void HM55B_Reset() {
set_digital_output(IO_B1, LOW);
ShiftOut(0B0000, 3);
set_digital_output(IO_B1, HIGH);
void HM55B_StartMeasurementCommand() {
ShiftOut(0B1000, 3);
int HM55B_ReadCommand() {
int result = 0;
ShiftOut(0B1100, 3);
result = ShiftIn(3);
return result;
void Read_Compass() {
int HM55B_result;
HM55B_StartMeasurementCommand(); // necessary!!
delayms(40); // the data is 40ms later ready
HM55B_result = HM55B_ReadCommand(); // read data and save Status
X_Data = ShiftIn(11); // Field strength in X
Y_Data = ShiftIn(11); // and Y direction
set_digital_output(IO_B1, HIGH); // ok deselect chip
angle = 180 * (atan2(-1 * Y_Data , X_Data) / M_PI); // angle is atan( -y/x) !!!
void blink_and_pause(int x)
// flash led for each digit in angle
int counter, y;
y = x;
if(x==0) y = 10;
for(counter=1;counter<=y;counter++)
DDRD |= 1 << PD1; // set LED pin PD1 to output
PORTD |= 1 << PD1; // LED on
delayms(200);
PORTD &= ~( 1 << PD1 ); //LED off
delayms(200);
delayms(3000); // end of digit
void flash_angle()
// LED flashes indicate integer value
// 1 flash -> 1
// 2 flashes -> 2
// 9 flashes -> 9
// 10 flashes -> 0 (special case)
// ex. angle = 037 degrees -> 10 flashes + pause + 3 flashes + pause + 7 flashes
int y, ones, tens, hundreds;
y = abs(angle); // ignore sign
hundreds = (int)(y/100);
tens = (int)((y - hundreds100)/10);
ones = y - tens10 - hundreds*100;
blink_and_pause(hundreds);
blink_and_pause(tens);
blink_and_pause(ones);
int main()
HM55B_Reset();
Read_Compass();
flash_angle();
while(1);
return 0;
[/code]
