I’m not sure what I’m doing wrong but I can’t seem to get the RC switch functioning.
I’ve connected the switch to the RC receiver as per the diagram. (black-ground, red-VRC, white-RC signal in)
The voltage across the black and red is between 4.8v to 5.1v (measured on the switch), yet the LED doesn’t indicate anything and the switch doesn’t function.
Things that I’ve tried…
- using 2 radio receivers/transmitters
- turned the receiver/s on and off to determine if lack of a signal does anything different.
- testing the receiver by attaching a servo to the channel that the switch was on. it works fine.
- tried a second 1210 RC switch, no difference.
- tried a different connector cable between the receiver and the switch.
- measured the voltage between the black and RC In (white) at the switch ( it varies between .24v to .39v depending on the position of the transmitter stick for that channel)
I’m obviously missing something pretty basic, but whatever that is, I need some help to determine.
cheers, Brian
