Having trouble with servo range on Mini Maestro – only getting 90° movement
I’m using a Mini Maestro 24 with MG996R servos on a hexapod project. When I send commands from 4000 to 8000 (quarter-microseconds), I only get about 45° each direction from center — 90° total. I know these servos can do 180° because they work fine with standard Arduino servo libraries using myservo.attach(7,500,2400) .
Is there a way to configure the Maestro to use the full 500-2400µs range? I’ve tried adjusting min/max in the Maestro Control Center, but maybe I missed something. Using the Pololu library on an Arduino Mega.
Any help appreciated.
I moved your post to a more appropriate section of the forum.
Your question sounds almost identical to this one posted yesterday, and you can find my replies there; are you associated with them in some way?
