http://s770.photobucket.com/user/69Rebuild/media/IMG_0180_zpsb5947c8e.mp4.html
Just have to paint it
That’s really creepy. I would love to hear more about how you made it. What components did you use? What are you going to paint?
- Jeremy
Hey Jeremy
I used the 6 channel Micro Maestro and a Hi-tech servo . I modified the servo to run continuous. I removed the potentiometer and soldered 2- 2.7K resistors in place so I could find an "off " position. I hot glued the head to a gear I got in the Hi Tech kit. I just messed with the timing in the 6 channel Micro Maestro. I stumbled through the programming until I got it at 360 degrees with the “Sequence” feature. I glued a small spst switch into the hand to run it. Thats really all
Yes, very creepy!!
