The datasheet for the 25D Metal Gearmotors states the Hall sensors require an input voltage, Vcc, between 3.5 V and 20 V and draw a maximum of 10 mA. With that in mind, what would be the best solution to interface this encoders with a 3.3V logic level MCU ? Was planing to use the 2200 RPM motor with the encoders A and B outputs connected to a interrupt pin on a MCU (I’m only mentioning this in case of someone sugesting a level shifter module, the switching needs to be high enough for the 2200 RPM pulses). Has anyone else used this with 3.3V MCU ? Thanks !
-Peixoto
