I’m having some issues setting up a 1m 60-LED strip WS2812B. I downloaded the library and uploaded the code to my Arduino Mega with no problems. I then connected the LED strip to PIN 12, Ground and 5V on the Arduino. Upon connecting and providing power, I noticed a few random LEDs blinking for a split second, then everything went dark and nothing else happened. The same random blink happened whenever I plugged the strip to Arduino’s 5V.
Thinking the problem must have been powering it from the Arduino, I then tried to power the strip using a 5V 5A external power supply and got the same result - a few random lights blink when power is connected, but all lights remain off after that. I measured the voltage with a multimeter and was getting 5V, so voltage was not the issue. I also tried to run it form an Arduino Uno instead of the Mega in case the Arduino was defective but the exact same thing happened.
So, far, I’ve only been able to get those few lights to blink when power is provided but nothing other than that. Any other testing/troubleshooting ideas or suggestions?
Thanks,
Felipe.
