Hi all,
I’m in a competition with my friends to create the fastest robot in a maze setting. I’m trying to create a constant gear that will result in long run times; the maximum gear is determined by the most challenging regions of track; therefore I need to shift my gears in challenging regions. I want to use the twenty most recent past vales of my ‘proportional’ term to adaptively change the speed of my robot. To do this I want to find a way to store the 20 most recent values of ‘proportional.’ I have to do this using a queue. Can someone look over my code and help me design this??
* This code will follow a black line on a white background, using an adaptive
* PID-based algorithm.
* https://www.pololu.com/docs/0J21
* https://forum.pololu.com
// The 3pi include file must be at the beginning of any program that
// uses the Pololu AVR library and 3pi.
#include <pololu/3pi.h>
// This include file allows data to be stored in program space. The
// ATmega168 has 16k of program space compared to 1k of RAM, so large
// pieces of static data should be stored in program space.
#include <avr/pgmspace.h>
// Introductory messages. The "PROGMEM" identifier causes the data to
// go into program space.
#include "maze.h"
#include "robotModel.h"
#include "useCurses.h"
#include <stdio.h>
#include <stdlib.h>
const char welcome_line1[] PROGMEM = " Pololu";
const char welcome_line2[] PROGMEM = "3\xf7 Robot";
const char demo_name_line1[] PROGMEM = "PID Line";
const char demo_name_line2[] PROGMEM = "follower";
// A couple of simple tunes, stored in program space.
const char welcome[] PROGMEM = ">g32>>c32";
const char go[] PROGMEM = "L16 cdegreg4";
const char increase[] PROGMEM = "L16 dd";
const char decrease[] PROGMEM = "L16 bb";
void run_proportional(int proportional, int speed);
void initialize();
int input_gear(int gear);
// Data for generating the characters used in load_custom_characters
// and display_readings. By reading levels[] starting at various
// offsets, we can generate all of the 7 extra characters needed for a
// bargraph. This is also stored in program space.
const char levels[] PROGMEM = {
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
// This function loads custom characters into the LCD. Up to 8
// characters can be loaded; we use them for 7 levels of a bar graph.
void load_custom_characters()
lcd_load_custom_character(levels+0,0); // no offset, e.g. one bar
lcd_load_custom_character(levels+1,1); // two bars
lcd_load_custom_character(levels+2,2); // etc...
lcd_load_custom_character(levels+3,3);
lcd_load_custom_character(levels+4,4);
lcd_load_custom_character(levels+5,5);
lcd_load_custom_character(levels+6,6);
clear(); // the LCD must be cleared for the characters to take effect
// This function displays the sensor readings using a bar graph.
void display_readings(const unsigned int *calibrated_values)
unsigned char i;
for(i=0;i<5;i++) {
// Initialize the array of characters that we will use for the
// graph. Using the space, an extra copy of the one-bar
// character, and character 255 (a full black box), we get 10
// characters in the array.
const char display_characters[10] = {' ',0,0,1,2,3,4,5,6,255};
// The variable c will have values from 0 to 9, since
// calibrated values are in the range of 0 to 1000, and
// 1000/101 is 9 with integer math.
char c = display_characters[calibrated_values[i]/101];
// Display the bar graph character.
print_character(c);
// Initializes the 3pi, displays a welcome message, calibrates, and
// plays the initial music.
void initialize()
unsigned int counter; // used as a simple timer
unsigned int sensors[5]; // an array to hold sensor values
// This must be called at the beginning of 3pi code, to set up the
// sensors. We use a value of 2000 for the timeout, which
// corresponds to 2000*0.4 us = 0.8 ms on our 20 MHz processor.
pololu_3pi_init(2000);
load_custom_characters(); // load the custom characters
// Play welcome music and display a message
print_from_program_space(welcome_line1);
lcd_goto_xy(0,1);
print_from_program_space(welcome_line2);
play_from_program_space(welcome);
delay_ms(1000);
clear();
print_from_program_space(demo_name_line1);
lcd_goto_xy(0,1);
print_from_program_space(demo_name_line2);
delay_ms(1000);
// Display battery voltage and wait for button press
while(!button_is_pressed(BUTTON_B))
int bat = read_battery_millivolts();
clear();
print_long(bat);
print("mV");
lcd_goto_xy(0,1);
print("Press B");
delay_ms(100);
// Always wait for the button to be released so that 3pi doesn't
// start moving until your hand is away from it.
wait_for_button_release(BUTTON_B);
delay_ms(1000);
// Auto-calibration: turn right and left while calibrating the
// sensors.
for(counter=0;counter<80;counter++)
if(counter < 20 || counter >= 60)
set_motors(40,-40);
else
set_motors(-40,40);
// This function records a set of sensor readings and keeps
// track of the minimum and maximum values encountered. The
// IR_EMITTERS_ON argument means that the IR LEDs will be
// turned on during the reading, which is usually what you
// want.
calibrate_line_sensors(IR_EMITTERS_ON);
// Since our counter runs to 80, the total delay will be
// 80*20 = 1600 ms.
delay_ms(20);
set_motors(0,0);
// This is the main function, where the code starts. All C programs
// must have a main() function defined somewhere.
int main()
unsigned int sensors[5]={0}; // an array to hold sensor values
unsigned int last_proportional=0;
int proportional=0;
int derivative=0;
int lap_index=-1; // starts the lap when the mark orthogonal to the track is detected
long integral=0;
int gear = 2; // default gear
unsigned long start_time; // variable to store the starting time
// set up the 3pi
initialize();
// Allows user to change gears using buttons.
gear = input_gear(gear);
// Start the program.
clear();
print("Go!");
// Play music and wait for it to finish before we start driving.
play_from_program_space(go);
while(is_playing());
unsigned long time = get_ms();
// This is the "main loop" - it will run forever.
while(1)
// Get the position of the line.
unsigned int position = read_line(sensors,IR_EMITTERS_ON);
// The "proportional" term should be 0 when we are on the line.
proportional = ((int)position) - 2000;
derivative = proportional - last_proportional;
integral += proportional;
last_proportional = proportional;
// GEAR SWITCHING CODE GOES HERE
print ("\n Enter")
// CALL PROPORTIONAL CONTROLLER WITH DIFFERENT SPEED SETTINGS
switch (gear) {
case 1: run_proportional(proportional, 64);
break;
case 2: run_proportional(proportional, 128);
break;
case 3: run_proportional(proportional, 164);
break;
case 4: run_proportional(proportional, 192);
break;
case 5: run_proportional(proportional, 232);
break;
// Increase lap index if all sensors are active; i.e., mark has been reached
if (sensors[0]>600 && sensors[1]>600 && sensors[2]>600 && sensors[3]>600 && sensors[4]>600 && (get_ms()-time)>100)
lap_index++;
time = get_ms();
if(lap_index == 0) // First mark: set the start time
start_time = time;
else if (lap_index == 1 ) { // Terminate and wait indefinitely in while loop if total number of laps exceed 1
set_motors(0,0);
clear();
left_led(0);
right_led(0);
position = read_line(sensors,IR_EMITTERS_OFF);
lcd_goto_xy(0,0);
print("RUN TIME");
lcd_goto_xy(0,1);
print_long(get_ms() - start_time);
while(1);
// This part of the code is never reached. A robot should
// never reach the end of its program, or unpredictable behavior
// will result as random code starts getting executed. If you
// really want to stop all actions at some point, set your motors
// to 0,0 and run the following command to loop forever:
while(1);
// This is the main line following code. It sets the speed of the individual motors to
// speed + powerdiff and speed - powerdiff. Here, powerdiff is determined as
// the current error weighted by 128/2000.
// The motor speeds are always restricted to be in the range [0,255]
float factor = 128/2000.0; // factor tuned so that proportional*factor in [-128,128]
float computed = (float)(proportional);
int power_difference = (int)(computed*factor);
// Compute the actual motor settings. We never set either motor
// to a negative value or greater than 255.
int lspeed = speed + power_difference;
int rspeed = speed - power_difference;
if(lspeed < 0) lspeed = 0;
if(rspeed < 0) rspeed = 0;
if(lspeed > 255) lspeed = 255;
if(rspeed > 255) rspeed = 255;
set_motors(lspeed, rspeed);
return;
// This function allows the users to increase or decrease the gears using the buttons
unsigned char buttons = BUTTON_A;
clear();
lcd_goto_xy(0,0);
print("A:< gear");
lcd_goto_xy(0,1);
print("C:> gear");
delay_ms(1000);
clear();
lcd_goto_xy(0,0);
print("B:OK");
lcd_goto_xy(0,1);
print("Gear "); print_long(gear);
buttons = wait_for_button(ANY_BUTTON);
while (buttons != BUTTON_B)
if (buttons == BUTTON_C) {
gear = gear + 1;
if(gear >5) gear = 5;
clear(); lcd_goto_xy(0,0); print("< OK >");
lcd_goto_xy(0,1); print("Gear "); print_long(gear);
else
gear = gear - 1;
if (gear<1) gear = 1;
return(gear);
