Any simple way of editing a post/topic title?
The tilte can only be edited when creating the topic but not after a few conversations.
I like adding a [SOLVED] at the end of a topic title once an issue has been solved.
Thx
Stephane
Thx
Stephane
You cannot edit the title of a post after the allotted time has passed. However, you can mark a response as the solution; this option can be found by clicking the “show more” button under the response (i.e. the 3 dots):
When a post is marked as the solution, it will have an indicator under the post, like this:
Additionally, that thread will have a checkbox in front of the topic title in list views, for example:
Hi Brandon,
Unfortunately your solution does not work…
As you can see on the following printscreen, I could not mark your last post as a solution because of missing “show more” option:
Am I missing something?
Stephane
Sorry for the confusion; we previously had the ability to mark a post as the solution turned off for topics under certain categories (like “About the Pololu Forum”). After discussing it a bit, we decided to just enable it for the entire forum, so it should be available now.
ok, thx
