I’m using this sensor with a microcontroller that goes into deepsleep after taking a measurement. Because I want it to take as minimal mAh as possible I thought it would be a good idea to switch from continuously operation (and cutting it after receiving 5 results) to single measurements without the continuously measurement in the background. However when doing this I noticed the first 2-3 results are always inaccurate. Any idea why this is the case?
#include <Wire.h>
#include <VL53L1X.h>
VL53L1X sensor;
void setup()
Serial.begin(115200);
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
sensor.setTimeout(500);
if (!sensor.init(true))
Serial.println("Failed to detect and initialize sensor!");
while (1);
sensor.setDistanceMode(VL53L1X::Short);
sensor.setMeasurementTimingBudget(200000);
void loop()
sensor.readSingle(false);
while (!sensor.dataReady())
delay(10);
Serial.print("function output: ");
Serial.print(sensor.readRangeSingleMillimeters());
Serial.print("\trange: ");
Serial.print(sensor.ranging_data.range_mm);
Serial.print(" mm\tstatus: ");
Serial.print(VL53L1X::rangeStatusToString(sensor.ranging_data.range_status));
Serial.print("\tpeak signal: ");
Serial.print(sensor.ranging_data.peak_signal_count_rate_MCPS);
Serial.print("\tambient: ");
Serial.print(sensor.ranging_data.ambient_count_rate_MCPS);
Serial.print("\tb: ");
Serial.print(sensor.getMeasurementTimingBudget());
Serial.println();
delay(1000);
Serial output:
19:26:37.812 -> function output: 41 range: 41 mm status: range valid peak signal: 260.68 ambient: 0.21 b: 199426
19:26:39.233 -> function output: 97 range: 97 mm status: range valid peak signal: 39.15 ambient: 0.02 b: 199426
19:26:40.620 -> function output: 103 range: 103 mm status: range valid peak signal: 17.70 ambient: 0.01 b: 199426
19:26:42.040 -> function output: 103 range: 103 mm status: range valid peak signal: 17.69 ambient: 0.01 b: 199426
19:26:43.412 -> function output: 103 range: 103 mm status: range valid peak signal: 17.62 ambient: 0.02 b: 199426
19:26:44.848 -> function output: 104 range: 104 mm status: range valid peak signal: 17.80 ambient: 0.01 b: 199426
19:26:46.225 -> function output: 103 range: 103 mm status: range valid peak signal: 17.73 ambient: 0.02 b: 199426
Thanks in advance
