What is the angular field of view of the Sharp optical distance sensor? I did not see this on the data sheet. Or maybe I should ask:
How wide does an object need to be to be seen.
If there is a wall with an open doorway, how wide in angles does the doorway need to be before it can be detected. I
What I’d like to do is place one of these on a motor and rotate it in steps and make a crude male of surroundings, I am wondering about the annular resolution of the resulting map. I’m guessing it will be maybe 20 degrees? But worse like 90?
I know the answer is “it depends” but I’m looking for ballpark numbers
