I need to change the output voltage of the D24V22F12 12 volt regulator slightly to about 11 volts. I have done this before on other Pololu regulators. Is a schematic or table available showing these values? Tthe D24V10F web page has a schematic and a table but I cannot use it because I need more current. Also the D24V22 board has a lot of resistors and it is not clear which is the high-side feedback resistor. Can anyone tell me which one it is? My plan is to solder a much larger resistor on top of it so it is electrically in parallel which will reduce the resitance so I get the lower voltage. I love the products and use them whenever I can.
Thank you for the kind words about our products; I’m glad to hear you’ve had good experiences with them!
The output voltage of the D24V22Fx regulators are governed by the following equation:
On the D24V22F12 board, R3 is 47kΩ and R4 is 3.3kΩ, and you can find them here:
I recommend keeping R3 somewhere around 40kΩ.
The 470 kΩ suggestion checks out . Using Brandon’s values:
- Effective R3: 47 kΩ ∥ 470 kΩ = 42.73 kΩ
- Output: 0.792 × (42.73 / 3.3 + 1) ≈ 11.05 V
For exactly 11.00 V in the nominal calculation, the added resistor would be approximately 448 kΩ , so 470 kΩ is a sensible standard value for your “about 11 V” target. The effective R3 also stays close to Brandon’s recommended range.
For the physical modification, I’d keep the added resistor directly across R3 with very short connections. The feedback node is sensitive to switching noise, so long flying leads near the inductor are worth avoiding. Analog Devices’ layout guidance and this article on inductor placement and feedback routing explain that coupling.
After soldering with power disconnected, check the output before reconnecting your equipment, then verify it at your intended load and input voltage. The calculated 11.05 V is nominal; resistor and reference tolerances will affect the measured result.
