Im planning to replace an old 5V PCB in a (commodore 64) powersupply with the D24V25F5
The system will be drawing between 1.5 and 2 A, and the input voltage will be between around 12V so within the specs.
However, the D24V25F5 will be mounted inside the current powersupply with less than normal airflow, so i want to put some extra (passive) cooling on to keep it from running too hot.
Are there special heatsinks for these type of stepdown regulators? Because i can’t seem to find much info online.
