Hey!
I wonder if motors with extended motor shaft (30:1 HPCB) will fit RRC04A chassis , 42mm x 19mm wheel and Pololu Micro Metal Gearmotor Bracket Extended Pair?
Have a nice day!
Hey!
Have a nice day!
The extended versions of the micro metal gearmotors should work with the chassis. If you are planning on using the encoders that go on the extended shaft instead of the wheel encoders, you will probably want to use the included spacers mentioned on the product page.
Grant
