Hello guys, I am a high school student and i urgently need your help with explanations. I created a small school project. and I need help on how to explain to my teacher the meaning of my generated script from the Pololu maestro controller.
currently i am a novice to using the Pololu maestro center controller, i read through the maestro user guide and did not find any information regarding the explanation of the meaning of generated scripts from the maestro controller and would kindly like if someone will be kind enough to explain to me the meaning of all this numbers that was generated when i moved my servos to several positions. i click on “copy sequence to scrip” and such script was generated.
please i will like to know what is the meaning of this cluster of numbers and what they represent ( 500 5664 6980 6980 0 6000 4964 )
i discovered that first four numbers that makes up the first group are totally different from the first number in the second row
please what is the meaning of ( sub frame_0…2_4_5_8…10_12_14_16_17_20_21 )
what does it represents
***# Sequence 1***
***begin***
***500 5664 6980 6980 0 6000 4964***
***4964 0 6000 6980 6980 0***
***6000 4964 4964 0 6000 6980***
***6980 0 6000 4964 4964 0*** ***frame_0..23*** ***# frame 0.***
***500 3968 3968 3968 8000 3968 3968***
***3968*** ***frame_4_5_8_9_20..22*** ***# frame 1***
***500 8000 4964 6000 6000 3968 8000***
***6000 6000*** ***frame_1_5_9_10_14_17_21_22*** ***# frame 2***
***500 6980 6000 6000 6980 6980 4964***
***6980 6000 4964 4964*** ***frame_1_4_8..10_14_17_20..22*** ***# frame 3***
***repeat***
please what is the meaning of ( ***sub*** ***frame_0…2_4_5_8…10_12_14_16_17_20_21*** )
i discovered that random numbers where repeated and with the ending servo example ( 8 servo) what does 5 servo represent in a layman’s word.
***sub*** ***frame_0..2_4_5_8..10_12_14_16_17_20_21***
***21*** ***servo***
***20*** ***servo***
***17*** ***servo***
***16*** ***servo***
***14*** ***servo***
***12*** ***servo***
***10*** ***servo***
***9*** ***servo***
***8*** ***servo***
***5*** ***servo***
***4*** ***servo***
***2*** ***servo***
***1*** ***servo***
***0*** ***servo***
***delay***
***return***
