After starting up the Arduino IDE (v1.8.13) I was prompted to update my board info and since then I cannot compile a working sketch for a board with the A-Star 328PB.
I see new options under Tools which weren’t there before, and with the default selections of Default I2C bus: “TWI0” and Default SPI bus: “SPI0” i get compile errors. On my other machine where I have NOT updated the board info I do not see those options and the sketch compiles successfully.
Error message:
Arduino: 1.8.13 (Mac OS X), Board: "Pololu A-Star 328PB, 5V, 16MHz, TWI0, SPI0"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/rwaddell/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/rwaddell/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/rwaddell/Dropbox/Arduino Projects/libraries -fqbn=pololu-a-star:avr:a-star328PB:version=16mhz,i2c=twi0,spi=spi0 -ide-version=10813 -build-path /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715 -warnings=none -build-cache /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_cache_307626 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /Users/rwaddell/Dropbox/Arduino Projects/LED_Strip_Brightness_Control_A-Star_328PB_v2/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/rwaddell/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/rwaddell/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/rwaddell/Dropbox/Arduino Projects/libraries -fqbn=pololu-a-star:avr:a-star328PB:version=16mhz,i2c=twi0,spi=spi0 -ide-version=10813 -build-path /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715 -warnings=none -build-cache /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_cache_307626 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/rwaddell/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /Users/rwaddell/Dropbox/Arduino Projects/LED_Strip_Brightness_Control_A-Star_328PB_v2/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino
Using board 'a-star328PB' from platform in folder: /Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0
Using core 'arduino' from platform in folder: /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5
Detecting libraries used...
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SevSeg.h: [SevSeg@3.7.0]
ResolveLibrary(SevSeg.h)
-> candidates: [SevSeg@3.7.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for ClickEncoder.h: [ClickEncoder]
ResolveLibrary(ClickEncoder.h)
-> candidates: [ClickEncoder]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for TimerOne.h: [TimerOne@1.1]
ResolveLibrary(TimerOne.h)
-> candidates: [TimerOne@1.1]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for jled.h: [JLed@4.11.0]
ResolveLibrary(jled.h)
-> candidates: [JLed@4.11.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_TLC59711.h: [Adafruit_TLC59711@1.3.0]
ResolveLibrary(Adafruit_TLC59711.h)
-> candidates: [Adafruit_TLC59711@1.3.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_SPIDevice.h: [Adafruit_BusIO@1.11.2]
ResolveLibrary(Adafruit_SPIDevice.h)
-> candidates: [Adafruit_BusIO@1.11.2]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg/SevSeg.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder/ClickEncoder.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src/esp32_hal.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src/jled_base.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711/Adafruit_TLC59711.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO/Adafruit_BusIO_Register.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO/Adafruit_I2CDevice.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src "/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO/Adafruit_SPIDevice.cpp" -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src/SPI.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src/Wire.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src/utility/twi.c -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/rwaddell/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328pb -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_A_STAR_328PB -DARDUINO_ARCH_AVR -DTWBR=TWBR0 -DTWSR=TWSR0 -DTWAR=TWAR0 -DTWDR=TWDR0 -DTWCR=TWCR0 -DTWAMR=TWAMR0 -DTWI_vect=TWI0_vect -DPIN_WIRE_SDA=PIN_WIRE_SDA0 -DPIN_WIRE_SCL=PIN_WIRE_SCL0 -DSPCR=SPCR0 -DSPSR=SPSR0 -DSPDR=SPDR0 -DPIN_SPI_SS=PIN_SPI_SS0 -DPIN_SPI_MOSI=PIN_SPI_MOSI0 -DPIN_SPI_MISO=PIN_SPI_MISO0 -DPIN_SPI_SCK=PIN_SPI_SCK0 -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/Users/rwaddell/Library/Arduino15/packages/pololu-a-star/hardware/avr/5.1.0/variants/a-star328pb "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed/src" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711" "-I/Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO" -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire/src -I/Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM/src /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp -o /var/folders/nb/2356s9gj6y714v9fzf4hck080000gn/T/arduino_build_82715/sketch/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino.cpp.o
In file included from /Users/rwaddell/Dropbox/Arduino Projects/LED_Strip_Brightness_Control_A-Star_328PB_v2/LED_Strip_Brightness_Control_A-Star_328PB_v2.ino:119:0:
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h: In member function 'void TimerOne::setPwmDuty(char, unsigned int)':
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:244:13: error: 'TIMER1_A_PIN' was not declared in this scope
if (pin == TIMER1_A_PIN) OCR1A = dutyCycle;
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:244:13: note: suggested alternative: 'TIMER1A'
TIMER1A
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h: In member function 'void TimerOne::pwm(char, unsigned int)':
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:253:13: error: 'TIMER1_A_PIN' was not declared in this scope
if (pin == TIMER1_A_PIN) { pinMode(TIMER1_A_PIN, OUTPUT); TCCR1A |= _BV(COM1A1); }
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:253:13: note: suggested alternative: 'TIMER1A'
TIMER1A
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h: In member function 'void TimerOne::disablePwm(char)':
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:268:13: error: 'TIMER1_A_PIN' was not declared in this scope
if (pin == TIMER1_A_PIN) TCCR1A &= ~_BV(COM1A1);
/Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne/TimerOne.h:268:13: note: suggested alternative: 'TIMER1A'
TIMER1A
Using library SevSeg at version 3.7.0 in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/SevSeg
Using library ClickEncoder in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/ClickEncoder (legacy)
Using library TimerOne at version 1.1 in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/TimerOne
Using library JLed at version 4.11.0 in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/JLed
Using library Adafruit_TLC59711 at version 1.3.0 in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_TLC59711
Using library Adafruit_BusIO at version 1.11.2 in folder: /Users/rwaddell/Dropbox/Arduino Projects/libraries/Adafruit_BusIO
Using library SPI at version 1.0 in folder: /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/SPI
Using library Wire at version 1.0 in folder: /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/Wire
Using library EEPROM at version 2.0 in folder: /Users/rwaddell/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/libraries/EEPROM
exit status 1
Error compiling for board Pololu A-Star 328PB.
Is it the new options? Does it matter what my sketch contains? Looks like it’s complaining about the TimerOne library (which I haven’t updated lately but is the same version as on the other machine where it compiles just fine).
