In the OrangutanDigital library the pins and ports for the ATmega1284p (Orangutan SVP) are not enumerated in a simple linear manner, but rather some of the ports are out of order, and some of the pin assignments are reversed (with MSB having a lower number than the LSB).
Eg…
#elif defined(__AVR_ATmega324P__) || defined(__AVR_ATmega644P__)|| defined(__AVR_ATmega1284P__) || defined(__AVR_ATmega324PA__) || defined(__AVR_ATmega644PA__)
// port D pins
#define IO_D0 0
#define IO_D1 1
#define IO_D2 2
#define IO_D3 3
#define IO_D4 4
#define IO_D5 5
#define IO_D6 6
#define IO_D7 7
// port B pins
#define IO_B0 8
#define IO_B1 9
#define IO_B2 10
#define IO_B3 11
#define IO_B4 12
#define IO_B5 13
#define IO_B6 14
#define IO_B7 15
// port C pins
#define IO_C0 16
#define IO_C1 17
#define IO_C2 18
#define IO_C3 19
#define IO_C4 20
#define IO_C5 21
#define IO_C6 22
#define IO_C7 23
// port A pins
#define IO_A0 24
#define IO_A1 25
#define IO_A2 26
#define IO_A3 27
#define IO_A4 28
#define IO_A5 29
#define IO_A6 30
#define IO_A7 31
Here the pins are flipped.
#if defined(_ORANGUTAN_SVP) || defined(_ORANGUTAN_X2)
else if (pin < 16) // pin 8 = PB0, ..., 15 = PB7
io->pinRegister = (unsigned char*)&PINB;
io->portRegister = (unsigned char*)&PORTB;
io->ddrRegister = (unsigned char*)&DDRB;
io->bitmask = 1 << (pin - 8);
else if (pin < 24) // pin 16 = PC0, ..., 23 = PC7
io->pinRegister = (unsigned char*)&PINC;
io->portRegister = (unsigned char*)&PORTC;
io->ddrRegister = (unsigned char*)&DDRC;
io->bitmask = 1 << (pin - 16);
else if (pin < 32) // pin 24 = PA7, ..., 31 = PA0
io->pinRegister = (unsigned char*)&PINA;
io->portRegister = (unsigned char*)&PORTA;
io->ddrRegister = (unsigned char*)&DDRA;
io->bitmask = 1 << (31 - pin);
#else
Is there are reason behind this?
I’m asking because I want to use your code for the Arduino Mega2560, and it didn’t work when I just enumerated the ATmega2560 ports & pins in the simple linear way. So, I thought I’d ask first before spending to much time to debug.
Regards, Phillip
