Hi, I bought a DSM44 servo. I wrongly assumed it could rotate more than 180 degrees, but the default with 20ms pulses is ~90 degrees max., while the max is ~135 degrees with 32ms pulses from my Micro Maestro 6. I tested the range with the Maestro Control Center. 32ms is the max allowed from the Maestro Control Center apparently. (I do not need to control more than two servos, so I do not know if there’s a way to increase the pulse periods)
Can you confirm this is the limit of this servo, and, more importantly could you suggest a few alternative servo models which allow a rotation of 180 degrees or more? I prefer a fast, micro servo, although it’s not necessary it to be micro.
Thanks.
