Hi everyone,
for a project I would like to control a stepper motor with CANape 14, this is software from the company VECTOR (- Installation of CANape 14 Service Pack 5 - Knowledge Portal).
CANape has its own programming language, which is called CASL, it very similar to C programming. The control should be done with a microcontroller pololu Tic T500 USB Multi-Interface with USB interface (Pololu - Tic T500 USB Multi-Interface Stepper Motor Controller).
According to my research, this should actually work by using the installed drivers as well as the Pololu SDK, it should be possible to write a CANape C-Function DLL, which can then also be controlled via panel from CANape.
I have already created a DLL with Visual Studio but unfortunately, it didn’t work with CANape 14.
do u have any Idea to control this motor in another way? or If u can help to make this DLL works on CANape.
Operating System: Windows 10
CANape version 14
Pololu Tic T500
Thank you a lot
Best regards
Junior
