We want to build a self guiding robot that is capable of measuring the distance between itself and an obstacle in front ( which may be in motion) and accordingly vary its speed. Both RF and IR techniques will do. Any suggestions?
I think any type of PID control would work.
Here is an example using proportional control
(from page 283:
http://www.parallax.com/dl/docs/books/edu/Roboticsv2_2.pdf):
' -----[ Title ]--------------------------------------------------------------
' Robotics with the Boe-Bot - FollowingBoeBot.bs2
' Boe-Bot adjusts its position to keep objects it detects in zone 2.
' {$STAMP BS2} ' Stamp directive.
' {$PBASIC 2.5} ' PBASIC directive.
DEBUG "Program Running!"
' -----[ Constants ]----------------------------------------------------------
Kpl CON -35
Kpr CON 35
SetPoint CON 2
CenterPulse CON 750
' -----[ Variables ]----------------------------------------------------------
freqSelect VAR Nib
irFrequency VAR Word
irDetectLeft VAR Bit
irDetectRight VAR Bit
distanceLeft VAR Nib
distanceRight VAR Nib
pulseLeft VAR Word
pulseRight VAR Word
' -----[ Initialization ]-----------------------------------------------------
FREQOUT 4, 2000, 3000
' -----[ Main Routine ]-------------------------------------------------------
DO
GOSUB Get_Ir_Distances
' Calculate proportional output.
pulseLeft = SetPoint - distanceLeft * Kpl + CenterPulse
pulseRight = SetPoint - distanceRight * Kpr + CenterPulse
GOSUB Send_Pulse
LOOP
' -----[ Subroutine - Get IR Distances ]--------------------------------------
Get_Ir_Distances:
distanceLeft = 0
distanceRight = 0
FOR freqSelect = 0 TO 4
LOOKUP freqSelect,[37500,38250,39500,40500,41500], irFrequency
FREQOUT 8,1,irFrequency
irDetectLeft = IN9
distanceLeft = distanceLeft + irDetectLeft
FREQOUT 2,1,irFrequency
irDetectRight = IN0
distanceRight = distanceRight + irDetectRight
NEXT
RETURN
' -----[ Subroutine – Get Pulse ]---------------------------------------------
Send_Pulse:
PULSOUT 13,pulseLeft
PULSOUT 12,pulseRight
PAUSE 5
RETURN
HTH
