I am using 2 Baby Orangutan B-328 controllers with a DX6i Trx and Rx and the 3piRC program to skid steer a robot with 4 wheels powered by 50:1 micrometal motors. The program is working very well to control the robot, but I do have one issue. My robot is a transformable robot so I only want the controllers to run the motors at certain times. Would anyone have an example code that could be easily written into the program I have to arm and disarm my wheel motors. I would like utilize the two inputs I have from my Rx which are Elev and Aile. Ideally the program would work sort of like arming my arduino board where I could hold the two inputs to their minimum position for 2 seconds to disarm and to their maximum positions for 2 seconds to arm the motors. I would really appreciate any help as I plan to learn more about the programming soon but for this project I would really like some snippets of code to achieve this objective. I see at the bottom of the program it says you can set the motors to 0,0 and then run a while loop which seems like it could work but I am just not sure how I would utilize this either. I’ll put the program below for reference.
* RC 3pi
* This 3pi robot program reads two standard radio-control (RC) channels and mixes
* them into motor control. Channel zero (connected to the PD0 input)
* handles forward and reverse, and channel one (connected to the
* PC5 input) handles turning.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <pololu/3pi.h>
* Receiver pulse timings
* Standard RC receivers output high pulses between 0.5 ms and 2.5 ms with a neutral
* position of about 1.5 ms. If your RC receiver operates with different pulse
* widths, change these constants below.
* The units of these constants is ticks of Timer1 which is set to tick every 3.2
* microseconds.
const int minPulseTime = 156; // 1 ms
const int neutralPulseTime = 469; // 1.5 ms
const int maxPulseTime = 780; // 2.0ms
const int maxLowPulseTime = 3000; // 9.6ms
struct ChannelStruct
volatile unsigned int prevTime;
volatile unsigned int lowDur;
volatile unsigned int highDur;
volatile unsigned char newPulse;
unsigned int pulse;
unsigned char error;
struct ChannelStruct ch[2];
* Pin Change interrupts
* PCI0 triggers on PCINT7..0
* PCI1 triggers on PCINT14..8
* PCI2 triggers on PCINT23..16
* PCMSK2, PCMSK1, PCMSK0 registers control which pins contribute.
* The following table is useful:
* AVR pin PCINT # PCI #
* PB0 - PB5 PCINT0 - PCINT5 PCI0
* PC0 - PC5 PCINT8 - PCINT13 PCI1
* PD0 - PD7 PCINT16 - PCINT23 PCI2
// This interrupt service routine is for the channel connected to PD0
ISR(PCINT2_vect)
// Save a snapshot of PIND at the current time
unsigned char pind = PIND;
unsigned int time = TCNT1;
if (pind & (1 << PORTD0))
// PD0 has changed to high so record the low pulse's duration
ch[0].lowDur = time - ch[0].prevTime;
else
// PD0 has changed to low so record the high pulse's duration
ch[0].highDur = time - ch[0].prevTime;
ch[0].newPulse = 1; // The high pulse just finished so we can process it now
ch[0].prevTime = time;
// This interrupt service routine is for the channel connected to PC5
ISR(PCINT1_vect)
// Save a snapshot of PINC at the current time
unsigned char pinc = PINC;
if (pinc & (1 << PORTC5))
// PC5 has changed to high so record the low pulse's duration
ch[1].lowDur = time - ch[1].prevTime;
else
// PC5 has changed to low so record the high pulse's duration
ch[1].highDur = time - ch[1].prevTime;
ch[1].newPulse = 1; // The high pulse just finished so we can process it now
ch[1].prevTime = time;
* updateChannels ensures the recevied signals are valid, and if they are valid
* it stores the most recent high pulse for each channel.
void updateChannels()
unsigned char i;
for (i = 0; i < 2; i++)
cli(); // Disable interrupts
if (TCNT1 - ch[i].prevTime > 35000)
// The pulse is too long (longer than 112 ms); register an error
// before it causes possible problems.
ch[i].error = 5; // wait for 5 good pulses before trusting the signal
sei(); // Enable interrupts
if (ch[i].newPulse)
cli(); // Disable interrupts while reading highDur and lowDur
ch[i].newPulse = 0;
unsigned int highDuration = ch[i].highDur;
unsigned int lowDuration = ch[i].lowDur;
ch[i].pulse = 0;
if (lowDuration < maxLowPulseTime ||
highDuration < minPulseTime ||
highDuration > maxPulseTime)
// The low pulse was too short or the high pulse was too long or too short
ch[i].error = 5; // Wait for 5 good pulses before trusting the signal
else
// Wait for error number of good pulses
if (ch[i].error)
ch[i].error--;
else
// Save the duration of the high pulse for use in the channel mixing
// calculation below
ch[i].pulse = highDuration;
int main()
ch[0].error = 5; // Wait for 5 good pulses before trusting the signal
ch[1].error = 5;
DDRD &= ~(1 << PORTD0); // Set pin PD0 as an input
PORTD |= 1 << PORTD0; // Enable pull-up on pin PD0 so that it isn't floating
DDRC &= ~(1 << PORTC5); // Set pin PC5 as an input
PORTC |= 1 << PORTC5; // Enable pull-up on pin PC5 so that it isn't floating
delay_ms(1); // Give the pull-up voltage time to rise
PCMSK1 = (1 << PORTC5); // Set pin-change interrupt mask for pin PC5
PCMSK2 = (1 << PORTD0); // Set pin-change interrupt mask for pin PD0
PCIFR = 0xFF; // Clear all pin-change interrupt flags
PCICR = 0x06; // Enable pin-change interrupt for masked pins of PORTD
// and PORTC; disable pin-change interrupts for PORTB
sei(); // Interrupts are off by default so enable them
TCCR1B = 0x03; // Timer 1 ticks at 20MHz/64 = 312.5kHz (1 tick per 3.2us)
while (1) // Loop forever
updateChannels();
// Every 100 ms display the pulse timings on the LCD
// this is good for debugging your RC 3pi but not necessary if
// you remove the LCD
if (get_ms() % 100)
lcd_goto_xy(0, 0);
print("ch1 ");
// Multiplying by 32/10 converts ticks to microseconds
print_unsigned_long(ch[0].pulse * 32 / 10);
print(" ");
lcd_goto_xy(0, 1);
print("ch2 ");
print_unsigned_long(ch[1].pulse * 32 / 10);
if (ch[0].error || ch[1].error)
// If either channel is not getting a good signal, stop
set_motors(0, 0);
else
* Mix calculation
* This calculation mixes the pulses from the two channels
* to make control intuitive. Channel 0 controls foward and
* reverse. When the pulse is longer than neutralPulseTime it
* adds to m1 and m2; when the pulse is shorter than nuetralPulseTime
* it subtracts from m1 and m2. Channel 1 controls rotation. When the
* pulse is longer than neutralPulseTime it subtracts from m1 and adds
* to m2; when the pulse is shorter than neutralPulseTime it adds to m1
* and subtracts from m2. m1 and m2 are then scaled so they fit within
* -255 to 255 range.
* Calibration
* Your transmitter/receiver might treat channels 0 and 1 differently
* than the receiver this code was developed for. If your 3pi turns
* when you expect it to go straight or vice versa, you may need to flip
* a sign in the calculation below or swap the connections at the receiver.
long m1 = (neutralPulseTime - (int)ch[0].pulse) + ((int)ch[1].pulse - neutralPulseTime);
long m2 = (neutralPulseTime - (int)ch[0].pulse) - ((int)ch[1].pulse - neutralPulseTime);
m1 = m1 * 255 / minPulseTime;
m2 = m2 * 255 / minPulseTime;
set_motors(m1, m2);
// This part of the code is never reached. A robot should
// never reach the end of its program, or unpredictable behavior
// will result as random code starts getting executed. If you
// really want to stop all actions at some point, set your motors
// to 0,0 and run the following command to loop forever:
// set_motors(0,0);
// while(1);
