I’m about to start my first robotic project (yes, very nooby) and I was hoping I could get some advice on how to directly control a 201:1 Micro Metal Gearmotor (item #1096) with a PIC microcontroller (ideally using PICBasic or PICBasic Pro code, as that’s what I use).
I’d like to use an H-Bridge so I can control the motor’s direction, but how do I control the speed? This simple code just turns on and off the motor (at full speed, I presume):
start:
pause 500
high 1 ' rotate motor in one direction
pause 1000
low 1 ' stop motor
pause 1000
high 0 'Rotate motor in opposite direction
pause 1000
low 0
goto start
Ideally, I’ll use a pot and buttons as inputs to change the speed and direction (unlike the sample above which just loops through changing the motor’s direction at what I presume is the full speed)
- Can I use a PWN command to set the motor speed?
- Apart from the capacitors connected across the motor leads, do I need any other type of components?
I have a Trex Jr controller but it seems like overkill for this simple need.
Any help would be much appreciated. I’ve tried looking for some sample PICBasic code here but didn’t find much, so any links to some sample code would also be great.
