Hi guys,
Im wondering if someone here can confirm what im trying to do is correct. Basically im trying to find the RPM of a motor (specifically the pololu 19:1 gear motor with encoder). Using an Atmega162 to control Qik2s12v10 which drives the motor and the mcu also reads the encoder channels.
I’l give as much of the code as I can here. Thanks in advance
#define INVTICK 7812 // this is 1 / 128us, to avoid using floating point math
#define RPM ((60L * INVTICK) / 64) // 64 CPR
void calc_enc_rpm(ROBOT *w)
if (w->enc_read)
w->enc_period = w->enc_period_diff = w->enc_period_end - w->enc_period_start; // calculate period since last update
if (w->enc_ticks > 1)
w->enc_period /= w->enc_ticks; // average period of all ticks during sampling interval
if (w->enc_period)
w->enc_speed = (int16_t)(RPM / w->enc_period);
else
w->enc_speed = 0; // no speed
w->enc_period_start = w->enc_period_end; // it starts from timer tick of last one
w->enc_ticks = 0; // need at least one new tick to measure period
void motor_rpm_test(void)
printf("\r*Motor RPM Test*\r");
for (int i = 0; i < 2000;) // get 2000 samples
if (rwheel.enc_read)
calc_enc_rpm(rw);
rwheel.enc_read = FALSE;
printf("R: EncSpd %d, enc_period %ld, enc_period_diff %ld\r", rwheel.enc_speed, rwheel.enc_period, rwheel.enc_period_diff);
i++;
void motorRightFwd(uint8_t speed)
if (speed > 127)
sendByte(MOTOR1FORWARDFASTPACKET);
sendByte(speed - 128);
else
sendByte(MOTOR1FORWARDPACKET);
sendByte(speed);
int main(void)
setup();
#if DEBUG
printf("\r\r********** Odometry Control v0.3 **********\r\r");
#endif
motorRightFwd(60);
motor_rpm_test();
while(1);
