In the photos that come with the S18V20xxx type regulators you show the board dimension, the mounting hole spacing and the text indicates that the smaller holes are .1 inch spacing, however there is no info on the position of the smaller holes relative to the mounting screw holes. I am trying to build a PCB on which i want to mount the regulator using the mounting holes but also solder header pins in the smaller holes and then solder these pins straight onto the PCB but don’t want to eye-ball the spacing. Any chance of either publishing the pcb layout or providing the coordinates of all the holes in a diagram?
By the way, i mentioned the S18V20xxx but the same goes for the rest of the products in the series.
