I’m using your very nice library for writing text data to an SPI OLED, and I really like being able to switch easily between large or small text. The issue with the code below is that when I turn data logging “on” with a compile directive the data are correctly logged – in the example about once every 15 seconds – but data are no longer displayed on the OLED.
Clearly, there is some kind of conflict between these two SPI devices – the OLED and the SD card. I know (or assume?) that when setting up the SPI connections for the OLED, I should use a CS pin other than 10, which is hard-wired on the data logging shield. Any suggestions how to fix this issue, so that data are displayed on the OLED (updating about once per second in the code) even while data are being logged?
Any help will be greatly appreciated!
#define DELAYTIME 1000L
#define SMALL 1
#define LOG 1
#include <PololuOLED.h>
// SPI pins in this order: CLK(SCK), MOS(SDA), RES, DC, CS
// CS to 7 instead of 10 to avoid conflict with data logger?
PololuSH1106 display(13, 11, 8, 9, 7);
// thermistor setup
const float B=3950.,R_base=100000.;
const int R_Pin=A1; float V_T,V_R,R_T,T_thermistor;
float T_base=25+273.15; // Base temperature to kelvins.
// RTC setup
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 rtc; // old dataloggers
//RTC_PCF8523 rtc; // new dataloggers
int YR,MON,DAY,HR,MIN,SEC;
// logging setup
#if LOG
#include <SPI.h>
#include <SD.h>
const int SDpin=10; // For UNO data logging shield.
File logfile;
char filename[]="SPI_TEST.CSV";
const int N=15; int cnt=0.;
#endif LOG
void setup() {
Wire.begin(); rtc.begin();
#if LOG
if (!SD.begin(SDpin)) Serial.println("Card failed.");
Serial.println("card initialized.");
logfile = SD.open(filename, FILE_WRITE);
if (!logfile) Serial.println("Couldn't create file.");
Serial.print("Logging to file "); Serial.println(filename);
// Optionally, write header line here, with logfile.flush
logfile.println("file header...");
logfile.flush();
#endif LOG
display.noAutoDisplay();
display.rotate180();
#if SMALL
display.setLayout21x8(); // 21 characters in 8 rows
display.gotoXY(0,0); display.print("Small");
display.gotoXY(0,1); display.print("OLED font");
display.gotoXY(0,2); display.print("21x8 chars");
#else
display.setLayout11x4(); // 11 characters in 4 rows
display.gotoXY(0,0); display.print("Basic");
display.gotoXY(0,2); display.print("11x4 chars");
#endif SMALL
display.display(); delay(2000);
display.gotoXY(0,2); display.print(" ");
display.display();
void loop() {
DateTime now=rtc.now();
YR=now.year(); MON=now.month();
DAY=now.day();
HR=now.hour(); MIN=now.minute(); SEC=now.second();
V_R=5.*analogRead(R_Pin)/1023;
//V_R is the voltage across the resistor.
// 5. - V_R is the voltage across the thermistor.
V_T=5.-V_R; R_T=R_base*V_T/V_R;
// In Arduino programming log() is the natural logarithm.
T_thermistor=(1./((log(R_T/R_base)/B)+(1./T_base)))-273.15;
//Serial.print("thermistor T: "); Serial.println(T_thermistor,2);
#if SMALL
#else
#endif SMALL
display.print("Thermistor:");
display.gotoXY(0,1); display.print(" ");
display.print(T_thermistor,1);display.print(" C");
display.gotoXY(0,3); display.print(" ");
if (HR<10) display.print('0');
display.print(HR);display.print(':');
if (MIN<10) display.print('0');display.print(MIN);
display.print(':');
if (SEC<10) display.print('0');display.print(SEC);
display.display();
#if LOG
cnt++;
if(cnt==N) {
logfile.print(YR); logfile.print('/');
logfile.print(MON);logfile.print('/');
logfile.print(DAY);logfile.print(' ');
logfile.print(HR); logfile.print(':');
logfile.print(MIN);logfile.print(':');
logfile.print(SEC);logfile.print(',');
logfile.print(DAY+HR/24.+MIN/1440.+SEC/86400.,6);
logfile.print(',');
logfile.print(T_thermistor,2);
logfile.println();logfile.flush(); cnt=0;
#endif LOG
delay(DELAYTIME);
