I am running the step-down from 24VDC supply. I can’t find a spec on the max input voltage for the shutdown pin. Can it be connected to the input supply voltage?
Never mind, I found the schematic and the IC data sheet. It appears the EN input can go to Vin but needs to go below 1v to disable the device.
Hi.
Yes, the nSHDN pin on our D24V6F5 regulator can handle voltages up to the VIN supply voltage.
-Claire
