Hello Pololu Team,
i want to use the Enable pin on my D24V50F5 (Pololu 5V, 5A Step-Down Voltage Regulator) to switch my project on and of…
(so there are less voltage-spikes…)
my power source are 4 Li-ion protected cells in series (10V - 16.8V)
(Lithium Ion Cylindrical Battery - 3.7v 2200mAh)
i just want to connect a simple Toggle Switch between GND and Enable.
these switches can bounce - do i need to make some HW de-bouncing?
or is the enable pin / controller resistant to some bouncing?
i read it has a soft-start function.
and i also can see about 13ms rise time of the voltage with a light test load (57mA - just 3 leds…) on my oscilloscope. so seems this works nicely
hope i don’t need HW de-bouncing
sunny greetings
stefan
