Hello ,
I was looking to connect a U3V70f15 board instead of the D24V22F5 on my PCB board as I am going to be supplying my board with less voltage. I was wondering if I was able to connect the respective pins of the U3V70f15 via jumper cables to be able to run my PCB off it. Is there any issues I need to be made aware of before doing so? As in, does the whole board share the same ground or does the GND pin correspond to its respective Vin or Vout on each side of the board?
Thank you
