Hi I want to use the D24V22F5 regulator to power a M590 GSM module, however the maximum supply voltage is 4.7 Volts. Could you tell me what feedback resistors I would need to change to reduce the output from 5V to 4V?
Thanks
Simon
Thanks
Simon
Hi, Simon.
To get a 4V output from your D24V22F5 regulator you should change the resistor (R4) shown in the picture below to a 6.2k 0603 resistor.
-Claire
Hi Clare,
Thanks for the quick response, I’ll give that a go.
Kind regards
Simon
