Hello - I’ve just bought a D24V150F12 and a D24V60F5 for a fixed power supply - these will be driven off a 24VDC power supply that has a max ripple of 300mv. The 12V will be pulling 10 to 12amps for up to 30mins at a time. The 5V will be a steady 2 to 3amp - ambient temp is 30’C where I live. Before I design and 3D print the enclosure do you recommend heatsinking these products and if so do you have a heat sink or heat dissipation specsto recommend? I assume that both power transistor on the top and the mosfets on the underside of the board will need heat sinks. Size \ weight is not a particular concern for me for this application longer term reliability is my priority
I have a 24VDC fan that will be run off Vin that I was intending to use anyway
Edit - apologies if this info is included on the site somewhere I am new to Pololu and couldn’t see anything in the product data sheets
