I am using a 4S lipoly pack (16.8V) to power a multirotor used for FPV. The video transmitter is 12V only and the camera is 5V. From the main battery I run to the D24V10F12 (12V 1A step down) which then feeds both the video transmitter and also feeds a D24V6F5 (5V 600ma step down) which feeds the camera.
When I plug in the battery I get little to no voltage output. Its as if the regulator isn’t coming online. If I disconnect the camera then it will power up the VTX and then I can plug the camera in and it will continue to work. It will just not bring it all up initially. The VTX and Camera draw close to 200ma. Also if I put a LC filter in between the 12V regulator and VTX then it also will not power up the VTX (even with camera disconnected).
Now if I swap that with the larger S18V20F12 then there is no problems. Everything comes right up.
On the VTX I do have two 220uf 16V caps. One on the 12v coming in and one on the 5V exiting the D24V6F5 stepdown going to the camera. I am not sure if these caps are causing too high of a inrush surge. They are soldered and hot glued so they are not easily removable at this point.
Any ideas? Thanks!
