I’m wondering if there is a datasheet that can show what current output the switch can provide given a 5V input at 3A. Are there more specs that can help me determine what the continuous current output is between 3-5V input at STP?
Thanks.
Thanks.
The Mini Pushbutton Power Switch with Reverse Voltage Protection, LV essentially connects your VIN source to the load on VOUT. So it should be able to handle the 3A that your input source can handle (since the power used by the switch itself is pretty negligible compared to 3A).
