I actually asked about this before, but got pulled away for something else. Now, I am back to find out if I can switch our current platform… this is for our soccer project…
The requirement:
entire robot fit in a 22cm cylindar
able to detect walls
seek an IR ball which rolls around… therefore, wider range will be necessary
able to identify color (blue vs yellow)
compass
minimum 16-bit because doing a lot triangulation calculation
the only thing missing is the compass sensor… questions:
– can I just use another I2C compass sensor
– We are currently using the compass sensor from the hitechnic.com . Since you do not carry a compass sensor, I wonder if you have any recommendation to create a cable interface between the controller stated earlier and another end uses an RJ-12-like connector… the interface used with the sensors at hitechnic.com.
In addition, I am looking for something solderless!
Your help will be greatly appreciated.
Hope that collected information is good to create a tiny robot… we try to create one to do the robosoccer and roborescue game at the rcj.robocup.org. If the platform is promising… we can potentially continue to get more… Or, you can post it as a new kit fro robosoccer too…
I do not really understand what you are asking. Are you asking if you can, in general, use an I2C compass sensor with the SVP-1284? The answer is that it is very likely to be possible, but will require some significant coding - if you think you are capable of coding it, could you ask some more specific questions about what you are stuck on?
To make a custom cable, I think you can take a 6-wire phone cable, cut off one end, and solder the ends to header pins or us our crimp connector pins. But that seems pretty obvious; did you have a more specific question in mind? I have never done anything with RCX-compatible sensors.
Your last question seems to be about whether you can attach a bunch of extra sensors to the 3pi. The answer is no, without additional control electronics, because the 3pi does not have much available I/O. See this page for more information.
