/* This JRK CRC-7 code was written by Daniel at Point1 Seconds Inc.
Pass in a pointer to an array of unsigned 8bit data along with the data length.
Make sure that your array is at least one byte longer than the length to store the CRC
It is free to use or modify as you like.
typedef unsigned char U8;
typedef unsigned short U16;
typedef unsigned int U32;
typedef signed char S8;
typedef signed short S16;
typedef signed int S32;
typedef signed long long S64;
typedef float F32;
typedef double F64;
typedef union _WORD {
U16 u16;
S16 s16;
struct {
U8 byte0;
U8 byte1;
U8 u8p[2];
}UW;
#define JRKpoly91 0x91
void jrkCalcPoly(U8* u8p_msg, U8 u8_Len){
U8 u8_Shifts, u8_MsgIdx = 1;
UW uw_CRC;
uw_CRC.u8p[0] = u8p_msg[0];
u8p_msg[u8_Len] = 0;
while(u8_MsgIdx <= u8_Len){
uw_CRC.u8p[1] = u8p_msg[u8_MsgIdx];
u8_MsgIdx++;
for(u8_Shifts = 0; u8_Shifts < 8; u8_Shifts++){
if(uw_CRC.u8p[0] & 0x01){
uw_CRC.u8p[0] ^= JRKpoly91;
uw_CRC.u16 >>= 1;
u8p_msg[u8_Len] = uw_CRC.u8p[0];
void jrkTransmit(U8* u8p_data, U8 u8_Len, U8 u8_NumBytesReturned){
jrkCalcPoly(u8p_data,u8_Len);
u8_Len++;
/* add your transmit and receive code here */
