Coupling to Pololu 2358 minature DC motor
cant find anything to couple to that little D on the end of the shaft, its so small
Just want some prototypes and many a long term viable coupler
something like a servo horn connection (not rod to rod coupling)
“The nylon output shaft is 2 mm in diameter with a 0.5 mm flat on one side, and the “D” section is 2.5 mm long”
any ideas?
To avoid confusion, please note that our company name is Pololu, not polulu. (I fixed this in the thread title.)
Unfortunately, we no longer carry any hardware specifically intended for the Sub-Micro Plastic Planetary Gearmotors and do not have any specific suggestions. In case it helps though, for the types of loads that these tiny motors are designed to work with, it oftentimes will be adequate to just find or make something that is somewhat close to the right fit, and then you could use small quantities of glue to help hold the attachment on.
Alternatively, if you need something that enables more robust connections, it might be better to look at our Micro Metal Gearmotors.
- Patrick
thank you
