I have this code that is for a picaxe and I would like to convert it to arduino c code. I have very little knowledge of the wire library so I need any help you guys can provide.
Here is the picaxe code
#picaxe 20x2
#no_table
' PICAXE-20X2 sample program for Lego NXT Sensors
' **** AXE216 i2c Experimenter Board Setup ****
' J1 External Power Fitted (4.5V)
' J2 SCL Pullup Not fitted (pullup is in sensor)
' J3 SDA Pullup Not fitted (pullup is in sensor)
' H2 9V Power Fitted (9V)
' Lego Ultrasonic Sensor (part 9846)
' Note this sensor is much more difficult than the other
' Lego sensors to use. Consider using the SRF005 instead!
' You must provide both 9V and 5V supplies .
' Also i2c needs to be hacked due to a bug in the ultrasonic i2c firmware
' This means only the ultrasonic sensor can be used at once on the i2c bus
' as we are now using a non-standard i2c protocol
' We recommnd using the SRF005 instead!
symbol distance = b0 'distance in cm
' Wires on NXT jack plug.
' Wire colours may vary. Pin 1 is always end nearest latch.
' 1 White +9V
' 2 Black 0V
' 3 Red 0V
' 4 Green +5V
' 5 Yellow SCL
' 6 Blue SDA
' Do not use i2c pullup resistor - already provided within sensor.
init:
'Slave address is $02
hi2csetup i2cmaster, $02, i2cslow, i2cbyte
hi2cout $41,($02) 'continuous mode
pause 100
main:
; read values
; This single line should work:
;hi2cin $42,(distance)
; but does not as dodgy firmware in ultrasonic sensor
; therefore here is the workaround
hi2cout ($42) ; address $42
low B.7 ; fake an extra pulse
input B.7 ; back to input
hi2cin (distance) ; read distance
; debug display
debug
; wait 1 second then loop
pause 1000
goto main
and here is what I have for arduino code which does not work(Nothing comes out of the serial port)
#include <Wire.h>
void setup()
Serial.begin(9600);
Wire.begin();
Wire.beginTransmission(0x41);
void loop()
Wire.send(0x42);
digitalWrite(19,LOW);
pinMode(19,INPUT);
char c = Wire.receive();
Serial.print(c);
delay(1000);
Thanks for the help.
