Hello everyone,
After extensive research, I came across several of your products and I’m hoping one of them will suit my project. I’m new to small electronics but I’m eager to learn and complete this correctly.
I’m attempting to retrofit a newer 2022 Toyota 4Runner hazard light switch into an older 2017 Toyota 4Runner. The 2017 switch is a latching type, whereas the 2022 switch is a momentary type. There are 4 wires leading to the switch, and I still need to pull the wiring diagrams to understand what each wire controls.
I believe it might be possible to use one of Pololu’s power switches to accomplish this by making the correct connections.
Could anyone advise if this task is feasible with any of the power switches listed here: Pololu Power Switches(Pololu Power Switches)? Is there any additional information required to choose the right product?
Thank you in advance for your help!
