Here is a sketch that uses functions I found that allow you to control servo motors without using any timers!!!
The servo is only held in position for a specific delay period so this sketch would be unsuitable for say a robotic arm, but just perfect for rotating a sensor. Also, by not holding the servo in position, the robot (or whatever thingy) saves power.
Before looking at this code, I did not fully understand how servo signal timing worked, but now I do.
Bloody simple.
I wish I thought of this myself.
Maybe later I’ll add some definitions, change the function to also accept angles by degrees and raw timing, and put this into a proper library and post the update here.
SoftServo.ino
* Softservo.ino
* software servo control without using timers
* note that these functions block until complete
void setup() // run once, when the sketch starts
softServoAttach(5);
void loop()
softServoWrite(90, 500);
delay(2000);
softServoWrite(45, 500);
delay(2000);
softServoWrite(135, 500);
delay(2000);
int servoPin;
void softServoAttach(int pin)
servoPin = pin;
pinMode(pin, OUTPUT);
// writes given angle to servo for given delay in milliseconds
void softServoWrite(int angle, long servoDelay)
int pulsewidth = map(angle, 0, 180, 544, 2400); // width in microseconds
do {
digitalWrite(servoPin, HIGH);
delayMicroseconds(pulsewidth);
digitalWrite(servoPin, LOW);
delay(20); // wait for 20 milliseconds
servoDelay -= 20;
while(servoDelay >=0);
