Alright, got tired of HyperTerminal to test the bi-directional UART communication. I poked around to find out programmatic ways for serial communication. I was successful in my attempt!
Time to give back to the community folks here. I was elated to find easier ways to now interface the Orangutan X2. Yeah, through Java
The following Java program is a simple multi-threaded event based reader that listens to the “COM5” port at 115200, 8, None and 1 Stop Bit. Please make sure you compile and program X2 board with the program posted by Ben that sends “Hello” when you press Reset button on the board.
Code Sample details: (For the Java enthusiasts )
The java code uses the RxTx library (rxtx.org/) which is an implementation of the javax.comm specification. See the import gnu.io.* line in the code. You can extend this program and you can use myriad open source java libraries (voice, opencv etc., ) to creatively interact with your Orangutan X2. Search for “SimpleWrite” in the web to look for code for writing to Orangutan X2.
Good Luck!!!
* @(#)SimpleRead.java 1.12 98/06/25 SMI
* Copyright 2003 Sun Microsystems, Inc. All rights reserved.
* SUN PROPRIETARY/CONFIDENTIAL. Use is subject to license terms.
* Sun grants you ("Licensee") a non-exclusive, royalty free, license
* to use, modify and redistribute this software in source and binary
* code form, provided that i) this copyright notice and license appear
* on all copies of the software; and ii) Licensee does not utilize the
* software in a manner which is disparaging to Sun.
* This software is provided "AS IS," without a warranty of any kind.
* ALL EXPRESS OR IMPLIED CONDITIONS, REPRESENTATIONS AND WARRANTIES,
* INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE OR NON-INFRINGEMENT, ARE HEREBY EXCLUDED. SUN AND
* ITS LICENSORS SHALL NOT BE LIABLE FOR ANY DAMAGES SUFFERED BY
* LICENSEE AS A RESULT OF USING, MODIFYING OR DISTRIBUTING THE
* SOFTWARE OR ITS DERIVATIVES. IN NO EVENT WILL SUN OR ITS LICENSORS
* BE LIABLE FOR ANY LOST REVENUE, PROFIT OR DATA, OR FOR DIRECT,
* INDIRECT, SPECIAL, CONSEQUENTIAL, INCIDENTAL OR PUNITIVE DAMAGES,
* HOWEVER CAUSED AND REGARDLESS OF THE THEORY OF LIABILITY, ARISING
* OUT OF THE USE OF OR INABILITY TO USE SOFTWARE, EVEN IF SUN HAS BEEN
* ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
* This software is not designed or intended for use in on-line control
* of aircraft, air traffic, aircraft navigation or aircraft
* communications; or in the design, construction, operation or
* maintenance of any nuclear facility. Licensee represents and
* warrants that it will not use or redistribute the Software for such
* purposes.
import java.io.*;
import java.util.*;
import gnu.io.*;
public class SimpleRead implements Runnable, SerialPortEventListener {
static CommPortIdentifier portId;
static Enumeration portList;
InputStream inputStream;
SerialPort serialPort;
Thread readThread;
public SimpleRead() {
try {
serialPort = (SerialPort) portId.open("OrangutanX2", 2000);
} catch (PortInUseException e) {}
try {
inputStream = serialPort.getInputStream();
} catch (IOException e) {}
try {
serialPort.addEventListener(this);
} catch (TooManyListenersException e) {}
serialPort.notifyOnDataAvailable(true);
try {
serialPort.setSerialPortParams(115200, SerialPort.DATABITS_8,
SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
} catch (UnsupportedCommOperationException e) {}
readThread = new Thread(this);
readThread.start();
public void run() {
try {
Thread.sleep(20000);
} catch (InterruptedException e) {}
public void serialEvent(SerialPortEvent event) {
switch (event.getEventType()) {
case SerialPortEvent.BI:
case SerialPortEvent.OE:
case SerialPortEvent.FE:
case SerialPortEvent.PE:
case SerialPortEvent.CD:
case SerialPortEvent.CTS:
case SerialPortEvent.DSR:
case SerialPortEvent.RI:
case SerialPortEvent.OUTPUT_BUFFER_EMPTY:
break;
case SerialPortEvent.DATA_AVAILABLE:
byte[] readBuffer = new byte[5];
try {
while (inputStream.available() > 0) {
int numBytes = inputStream.read(readBuffer);
System.out.print(new String(readBuffer));
break;
public static void main(String[] args) {
boolean portFound = false;
String defaultPort = "COM5";
if (args.length > 0) {
defaultPort = args[0];
portList = CommPortIdentifier.getPortIdentifiers();
while (portList.hasMoreElements()) {
portId = (CommPortIdentifier) portList.nextElement();
if (portId.getPortType() == CommPortIdentifier.PORT_SERIAL) {
if (portId.getName().equals(defaultPort)) {
System.out.println("Found port: "+defaultPort);
portFound = true;
SimpleRead reader = new SimpleRead();
if (!portFound) {
System.out.println("port " + defaultPort + " not found.");
To Compile and Run:
Use Eclipse or your choice of IDE (skipping details) and compile SimpleRead.java
Run SimpleRead which listens to Serial communication from X2.
You will see the following output:
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
Now press the Reset button in the Orangutan X2 board. You will see:
Stable Library
Hello
Enjoy!!!
Cheers,
