Hi guys, i’m doing a small robotics project and i’m having some problems turning the servo’s on. Heres the setup:
5v power supply
USB -> Serial connection
8-bit pololu servo controller ss03a
Servos are Hi-Tec HS422, and Hi-Tec 5995TG
Everything performs exactly as expected, except for after a restart. The Servo is left in a position x and not moved by hand. The servo and controller are restarted. The first command sent to the servo then makes it move to 135 degrees, then on the reissuing of the command the servo moves to the correct position. I’ve tried everything i can think of to get the servo to behave itself, starting with ordering it to move to its current position at full speed before any other commands. I’ve tried ensuring the servo is switched on, and setting the neutral position incase that was somehow causing the problem. Commands are as follows:
Set servo position to 90
0x80 0x01 0x04 0x00 0xa 0x18
Power off servo controller
Set servo to 'on’
0x80 0x01 0x00 0x5f
Set neutral to 90
0x80 0x01 0x05 0x00 0xa 0x18
set position to 90 -> servo moves to 135 degrees
set position to 90 -> servo moves to 90 degrees
I’ve tried doing this using both C++ and a Python script but it always does the same thing!
I’m slowly comming tot he conclusion that either it’s broken, or i’m stupid!
ALL input welcome
