I would like to expose the “draft” of a project and ask you two question about the use of Maestro 6 to control servos and leds using a Reed Switch.
My intention is the following:
A) Use the “button or switch to control servos” script to control 1 servo and 2 sets of LEDs connected to three different channels on a Micro Maestro 6.
B) The servo must stay running all the time when “on”.
C) One set of LEDs (X) is to stay steady when “on”.
D) The other set (Y) is to fade in and out when “on”, thanks to a little circuit which the set will be attached to. The circuit, for his turn, will be connected to the controller.
E) I will use a magnectic reed switch to act as the puch button on the script.
F) The sequence will be:
Everything is off;
Pass a magnet over the reed switch - the Set Y goes “on”, staying pulsing;
Pass a magnet over the reed switch - the Set Y goes “off” AND, at the same time, the Set X AND the Servo go “on”;
Pass a magnet over the reed switch - the Set X AND the Servo go “off” AND, at the same time, the Set Y goes “on”, staying pulsing;
Pass a magnet over the reed switch - the Set Y goes “off”.
END
G) I would like to know:
I suppose I can use a magnectic reed switch instead of the puch button. Is that right?
I don’t want the servo going from position a to b but to remain running until I turn it off. I also suppose that this is possible by modifications on the script, right?
I do not see anything wrong with using a reed switch with the Maestro the same way you would a pushbutton. I am not sure what you mean when you say you want the servo to remain running until you turn it off. Do you mean continue rotating in one direction? If so, you should use a continuous rotation servo, which allow you to control the speed of the servo with hobby RC servo signals (instead of the position like a standard servo).
By the way, it sounds like you might have some kind of additional circuitry for controlling your LEDs; is this the case? Depending on your LEDs, it is usually good practice to avoid powering an LED directly from an I/O pin by using something like a MOSFET.
Yes, I want the servo to rotate continuously until receive a command to stop. Is there any problem to connect a servo like this directly to a channel? I would like to make the servo rotation speeds up by increments until reach a desired velocity.
About the Leds, yes, both sets have several leds. One of them is pretty simple, being just six Leds connected in serie; the other set is composed of four Leds driven by a circuit which makes them to fade in and out.
Both sets will be connected to separate channels on the Maestro 6. Would that be possible?
You can control a servo directly from a Maestro channel (the Maestro provides the logic signal, which does not need to source a lot of current). Please note that you will still need to power the servo. You can find more information about options for this in the Powering the Maestro section of the Meastro user’s guide.
It sounds like you might not be familiar with continuous rotation servos. Continuous rotation servos allow you to control the speed of the servo with standard servo signals (instead of the position). The speed will be determined by how far the pulse width signal is away from the neutral (which is typically around 1500us). If you are interested in more details about servos and how they work, you might consider reading through our Introduction to servos series of blog posts.
It is possible to connect your different groups of LEDs to the Maestro, but as I mentioned previously, you should not be driving the LEDs directly from the Maestro I/O pins. You might consider using some RC switches with small low-side MOSFET to safely control power to your LEDs using the Maestro:
I built the circuit and everything was ok except for one detail. I am using
a continuous rotating servo which has only two wires (+ and GND).
The positive wire has to be connected to the signal pin of the channel or,
otherwise, the servo would be continuously running and I want it to be
turned on just when needed.
However, the signal pin delivers only around 3V and the servo needs 9V. I
think that the only way to bypass this problem would be installing a
voltage regulator to step-up the voltage from the signal pin to the servo.
Is that right?
I doubt you are using a continuous rotation servo. Continuous rotation servos have the same control interface as standard servos, which have a 3-wire interface: signal, power, and ground. I strongly recommend reading this blog post to better your understanding of continuous rotation servos.
I suspect that you have a DC motor. Unfortunately, the Maestro cannot control DC motors directly, so you will need an additional device in between the Maestro and motor. I recommend using an electronic speed controller (ESC), which is a motor controller that respond to servo signals. We have a line of Simple Motor Controllers that can act as an ESC which you could use, but you could probably find simpler, cheaper options on other RC hobby sites.
Yes, it should be a DC motor. I am a novice. Sorry!
However, since I don’t need to control it’s speed, nor the direction, could
the solution I presented works?
I only need the motor to turns on and off in an sequence and moment
programmed in the script.
When the script commands “turns on the channel”, the 3V issued by the
signal pin would be stepped-up to 9V by a voltage regulator connected to
signal and GND pins and the motor connected to the output of the VR would
run until the scrip commands “turns the channel off”.
The Micro Maestro’s signal pins can only source up to 20mA, which is probably not enough to even start spinning your motor, so using a step-up voltage regulator will not work. It would be best to use an RC switch with small low-side MOSFET to control the power to your motor from your Maestro as Brandon suggested in his last response to you.
