hello,
I want to control 48 motors with arduino.
So i got two Mini Maestro 24-Channel USB Servo Controllers.
I succeed in chaining two controllers with this code.
(Using aruino mega 2560 and power came from 5v/60A power supply.)
[code]int minDeg=1000 ;
int maxDeg=2000;
int deg[48];
int delta=1;
void setup() {
Serial.begin(115200);
for (byte i=0;i<48;i++) {
deg[i]=2000;
void loop() {
doDeg();
doMove1();
doMove2();
delay(5);
void doDeg() {
for (int i=0;i<48;i++) {
deg[i]-=delta;
deg[i]=constrain(deg[i],minDeg,maxDeg);
if ((deg[i]==minDeg)||(deg[i]==maxDeg)) {
delta*=-1;
void doMove1() {
Serial.write(0xAA); // command
Serial.write(0x0C); // device number
Serial.write(0x1F); // motor to forward
Serial.write(24);
Serial.write(0);
for (byte i=0;i<24;i++) {
Serial.write((deg[i]*4)&0x7F);
Serial.write(((deg[i]*4)>>7)&0x7F);
void doMove2() {
Serial.write(24);
Serial.write(0);
for (byte i=24;i<48;i++) {
[/code]
This case, the motors moved at the same time, same angle.
But now, i want to control each motor.
So i tried with this code
[code]#define sw_pin 7
void setup()
Serial.begin(9600);
pinMode(sw_pin,INPUT_PULLUP);
void set_target(unsigned char servo, unsigned int target){
//Send a Pololu Protocol command
Serial.write(0xAA); //start byte
Serial.write(0x0C); //device id
Serial.write(0x04); //command number
Serial.write(servo); //servo number
Serial.write(0);
Serial.write((target*4) & 0x7F);
Serial.write(((target*4) >> 7) & 0x7F);
void loop()
if(digitalRead(sw_pin) == HIGH){
set_target(0,1000);
delay(1000);
set_target(0,2000);
delay(1000);
set_target(2,1000);
delay(1000);
set_target(2,2000);
delay(1000);
set_target(1,1000);
delay(1000);
set_target(1,2000);
delay(1000);
set_target(3,1000);
delay(1000);
set_target(3,2000);
delay(1000);
}[/code]
And It works. but i want to change the speed of motors slow.
I know that I can control the motor speed 0-127(0x00-0x7F).
So i changed 7F -> 01, but i didn’t work.
how can i change the speed of motors?
Thanks for reading :^)
